Einleitung
If you are having troubles with your keyboard, this guide will teach you how to remove and replace it.
Was du brauchst
Use a plastic opening tool and carefully pry the top panel from the base.
Slowly lift the keyboard from the base.
Disconnect the attached ribbon from under the keyboard.
Abschluss
