Einleitung
This guide will walk through the steps to replace the RAM in your device. It does not involve any major disassembly and only requires a screwdriver and plastic opening tool.
Was du brauchst
Remove the two 4.6mm screws using the J0 Phillips head screwdriver.
Then use the plastic opening tool to open the RAM door.
