Zum Hauptinhalt wechseln
Asus Eee PC 1215N Hard Drive Replacement
Was du brauchst
  1. Asus Eee PC 1215N Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Asus Eee PC 1215N Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Asus Eee PC 1215N Hard Drive Replacement, RAM: Schritt 2, Bild 1 von 3 Asus Eee PC 1215N Hard Drive Replacement, RAM: Schritt 2, Bild 2 von 3 Asus Eee PC 1215N Hard Drive Replacement, RAM: Schritt 2, Bild 3 von 3
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N Hard Drive Replacement: Schritt 4, Bild 1 von 2 Asus Eee PC 1215N Hard Drive Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $3.99
    Kaufen
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Asus Eee PC 1215N Hard Drive Replacement, Top Cover (Touchpad): Schritt 5, Bild 1 von 1
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Asus Eee PC 1215N Hard Drive Replacement: Schritt 6, Bild 1 von 3 Asus Eee PC 1215N Hard Drive Replacement: Schritt 6, Bild 2 von 3 Asus Eee PC 1215N Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
  7. Asus Eee PC 1215N Hard Drive Replacement: Schritt 7, Bild 1 von 2 Asus Eee PC 1215N Hard Drive Replacement: Schritt 7, Bild 2 von 2
    Spudger
    $3.99
    Kaufen
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
  8. Asus Eee PC 1215N Hard Drive Replacement, Keyboard: Schritt 8, Bild 1 von 3 Asus Eee PC 1215N Hard Drive Replacement, Keyboard: Schritt 8, Bild 2 von 3 Asus Eee PC 1215N Hard Drive Replacement, Keyboard: Schritt 8, Bild 3 von 3
    • Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
    • Remove the keyboard 4 screws on the bottom.
    • Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
  9. Asus Eee PC 1215N Hard Drive Replacement: Schritt 9, Bild 1 von 1
    Spudger
    $3.99
    Kaufen
    • At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
    • Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
    • The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
  10. Asus Eee PC 1215N Hard Drive Replacement: Schritt 10, Bild 1 von 2 Asus Eee PC 1215N Hard Drive Replacement: Schritt 10, Bild 2 von 2
    Spudger
    $3.99
    Kaufen
    • Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
    • Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
    • Now you can remove the keyboard.
  11. Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: Schritt 11, Bild 1 von 3 Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: Schritt 11, Bild 2 von 3 Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: Schritt 11, Bild 3 von 3
    • Peel off the protective tape at the bottom left corner.
    • Peel off the warranty void at the bottom right corner and remove the screw below.
    • Remove the 6 other screws.
  12. Asus Eee PC 1215N Hard Drive Replacement: Schritt 12, Bild 1 von 2 Asus Eee PC 1215N Hard Drive Replacement: Schritt 12, Bild 2 von 2
    • Remove the protector plate.
  13. Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: Schritt 13, Bild 1 von 3 Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: Schritt 13, Bild 2 von 3 Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: Schritt 13, Bild 3 von 3
    • Remove the four Phillips #00 screws from the hard drive caddy.
    • Peel off any tape covering the hard drive, there is no need to remove it entirely.
  14. Asus Eee PC 1215N Hard Drive Replacement: Schritt 14, Bild 1 von 3 Asus Eee PC 1215N Hard Drive Replacement: Schritt 14, Bild 2 von 3 Asus Eee PC 1215N Hard Drive Replacement: Schritt 14, Bild 3 von 3
    • Unplug the hard drive by sliding it to the right, toward the USB ports.
    • Remove the hard drive.
Abschluss
25 weitere Nutzer:innen haben diese Anleitung absolviert.
Gaetan
9.574 Reputation
18 Anleitungen geschrieben
7 Kommentare
I've just upgraded my 1215N HDD using this guide. This is very good step by step guide. A WIndows 10 Pro install managed to wreck the pre-installed HDD.
Like Tolidano , I just used a normal flat head screwdriver and a Philips screwdriver to carry out the HDD swap. I'm now in the process of installing Windows 10 Pro on to the new HDD.
Richard Bijster - Antwort
Very good guide! I my case i need to remove 2 screws from the battery compartment to remove the keyboard
gus - Antwort
I also had to remove the two (tiny, but phillips #00) screws from the battery compartment.
I actually went further and removed the motherboard to clean the fan. It wasn't too hard thanks to your guide!
Franciozzy - Antwort
I, too had to remove the battery compartment screws. Other than that, and that I couldn’t get the keyboard cable out, the replacement went flawlessly.
Guy, Just Some -
Great stuff, swapped original HD for an SSD. Thank you for this!
Steven - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 27
Insgesamt: 15,810
