Einleitung
Removing the top cover is a mandatory step before to access the keyboard screw and go deeper inside the Eee PC 1215N.
  1. Turn the power off and turn the netbook upside down.
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Locate the memory compartment.
    • Locate the memory compartment.
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
    • Remove the screws as necessary.
      • For top cover removing, only remove the 2 bottom screws.
      • For Keyboard removing, remove all 4 screws.
      • The one short screw paterns to uper left screw hole directly on the PCB.
    • Use a Plastic Opening Tools to release the top cover.
      • Start from the left side.
      • Go around on the bottom
      • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
Abschluss
Gaetan
Mitglied seit 26.12.2012
9.316 Reputation
18 Anleitungen geschrieben
Unrelated. My Asus VX-6 recently had the blue USB 3.0 ports stop working. Now the Ethernet connection is intermittent, goes away, come back, over and over again. Are those 3 ports on the right hand side part of the main board or separate boards?
paul poco - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 2,289
