Zum Hauptinhalt wechseln
Asus Eee PC 1215N Top Cover (Touchpad) Replacement
Was du brauchst
    1. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Battery: Schritt 1, Bild 1 von 2 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Battery: Schritt 1, Bild 2 von 2
      • Turn the power off and turn the netbook upside down.
      • Slide both battery catches together to release the battery.
      • Slide the battery out.
      Frag FixBot
      Kommentar hinzufügen
    1. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: Schritt 2, Bild 1 von 3 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: Schritt 2, Bild 2 von 3 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: Schritt 2, Bild 3 von 3
      • Locate the memory compartment.
      • Using a Plastic Opening Tools, remove the screw rubber cover.
      • Remove the screw.
      Frag FixBot
    2. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: Schritt 3, Bild 1 von 1
      • Use a Plastic Opening Tools near the screw hole to release the cover.
      • Remove the cover
      Frag FixBot
    3. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: Schritt 4, Bild 1 von 2 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: Schritt 4, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      Spudger
      $3.99
      • Using a Spudger, push both right and left metal clip to release one of the RAM module.
      • Slide out the RAM module.
      • Do the same with the second RAM module if necessary.
      Frag FixBot
    1. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Top Cover (Touchpad): Schritt 5, Bild 1 von 1
      • Remove the screws as necessary.
      • For top cover removing, only remove the 2 bottom screws.
      • For Keyboard removing, remove all 4 screws.
      • The one short screw paterns to uper left screw hole directly on the PCB.
      Frag FixBot
    2. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: Schritt 6, Bild 1 von 3 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: Schritt 6, Bild 2 von 3 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: Schritt 6, Bild 3 von 3
      • Use a Plastic Opening Tools to release the top cover.
      • Start from the left side.
      • Go around on the bottom
      • Finish with the right side.
      • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
      Frag FixBot
    3. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: Schritt 7, Bild 1 von 2 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: Schritt 7, Bild 2 von 2
      Spudger
      $3.99
      • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
      • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
      • Now you can remove the top cover
      Frag FixBot
Abschluss
Gaetan
9.613 Reputation
18 Anleitungen geschrieben
1 Kommentar zur Anleitung
Unrelated. My Asus VX-6 recently had the blue USB 3.0 ports stop working. Now the Ethernet connection is intermittent, goes away, come back, over and over again. Are those 3 ports on the right hand side part of the main board or separate boards?
paul poco - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 3,132
