Zum Hauptinhalt wechseln
Asus Eee PC 900 LCD Display Screen Replacement
Was du brauchst
  1. Asus Eee PC 900 LCD Display Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Asus Eee PC 900 LCD Display Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Asus Eee PC 900 LCD Display Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
    Frag FixBot
  2. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
    Frag FixBot
  3. Asus Eee PC 900 LCD Display Screen Replacement, Keyboard: Schritt 3, Bild 1 von 2 Asus Eee PC 900 LCD Display Screen Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
    Frag FixBot
  4. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 4, Bild 1 von 2 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 4, Bild 2 von 2
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
    Frag FixBot
  5. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 5, Bild 1 von 1
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
    Frag FixBot
  6. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the keyboard by lifting upwards.
    Frag FixBot
  7. Asus Eee PC 900 LCD Display Screen Replacement, Top Cover: Schritt 7, Bild 1 von 2 Asus Eee PC 900 LCD Display Screen Replacement, Top Cover: Schritt 7, Bild 2 von 2
    • Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
    Frag FixBot
  8. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 8, Bild 1 von 2 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
    Frag FixBot
  9. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 9, Bild 1 von 3 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 9, Bild 2 von 3 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 9, Bild 3 von 3
    • Flip the laptop back over and identify the touchpad ribbon.
    • Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
    Frag FixBot
  10. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 10, Bild 1 von 1
    • Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
    Frag FixBot
  11. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 11, Bild 1 von 1
    • Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
    Frag FixBot
  12. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 12, Bild 1 von 3 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 12, Bild 2 von 3 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 12, Bild 3 von 3
    • Caution: To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage.
    • Remove the laptop cover.
    Frag FixBot
  13. Asus Eee PC 900 LCD Display Screen Replacement, LCD Display Screen: Schritt 13, Bild 1 von 3 Asus Eee PC 900 LCD Display Screen Replacement, LCD Display Screen: Schritt 13, Bild 2 von 3 Asus Eee PC 900 LCD Display Screen Replacement, LCD Display Screen: Schritt 13, Bild 3 von 3
    • Remove the large black wire using a plastic opening tool.
    Frag FixBot
  14. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 14, Bild 1 von 3 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 14, Bild 2 von 3 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 14, Bild 3 von 3
    • Gently pry off the six rubber covers around the outside of the screen using a two mm flat head screwdriver.
    • A flat head screwdriver is preferable over a spudger as the spudger's head is not thin enough to to slip under the rubber covers.
    • Remove the six 4.76 mm Phillips #0 screws underneath each cover.
    Frag FixBot
  15. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 15, Bild 1 von 1
    • Using a plastic opening tool, carefully detach the casing around the screen cover.
    • Remove the screen cover.
    Frag FixBot
  16. Asus Eee PC 900 LCD Display Screen Replacement: Schritt 16, Bild 1 von 3 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 16, Bild 2 von 3 Asus Eee PC 900 LCD Display Screen Replacement: Schritt 16, Bild 3 von 3
    • Remove the four 4.76mm Phillips #0 screws located on the corners of the screen.
    • Lift out the display screen.
    Frag FixBot
Abschluss
16 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 3-27, Amido Winter 2012 Mitglied von Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Mitglieder
16 Anleitungen geschrieben
2 Kommentare zur Anleitung
Another PERFECT iFixIt guide!
Had to replace the screen in one of these little beauties, and this walk-through worked like all iFixIt tutorials: Flawlessly.
Kudos Mr. Barker!
WildBill - Antwort Teilen
Perfect guide, thank you.
Roberto Zoni - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 94
Insgesamt: 15,793
