Ersatzteile
Kein Ersatzteil erforderlich.
Slide the battery's locking tabs from the locked position to unlocked positions.
The right tab is unlocked when a red dot is showing.
The left tab will have to be held in the unlocked position in order to release the battery.
Slide the battery out while holding the left locking tab in the unlocked position.
Identify the three metal tabs holding down the laptop's keyboard.
Using a spudger, depress each metal tab to remove the keyboard.
Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
Slide the keyboard's ribbon cable from the connector.
Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
Flip the laptop back over and identify the touchpad ribbon.
Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
6 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
If you have a 900HD, there are only 8 screws in step 7. The ninth "screw" -- the second from the right in the bottom row, to the right of the blue ribbon -- is under the hard drive. You have to remove the hard drive cover on the bottom, remove the hard drive, then remove the screw there.
how much the replacement of top and back cover of this laptop?
