Einleitung
If your tablet doesn't power on after charging, connect the power adapter. If it powers on after connecting the adapter, follow these steps to replace your battery.
Was du brauchst
Locate the sliding tab on the right and slide it to the left in order to unlock the battery.
Use a plastic opening tool to lift the battery up as you slide the tab on the left to the right.
2 weitere Personen haben diese Anleitung absolviert.
