Einleitung
If you would like to replace your wireless NIC then this is the guide that you have been looking for.
Was du brauchst
Locate the sliding tab on the right and slide it to the left in order to unlock the battery.
Use a plastic opening tool to lift the battery up as you slide the tab on the left to the right.
Turn the tablet over and open it up. Insert a nylon spudger into the slots above F1, F6, F10 to pry up the keyboard.
Once you have the keyboard out, use the nylon spudger to remove the connection. You can now replace the keyboard.
Locate the wireless NIC (network interface card).
Use a nylon spudger to lift the wireless antenna from the NIC and remove the screws.
