Einleitung
This guide will help you replace your Asus EeeBook X205TA in case your battery is dead, dying, or won't hold a charge. If disposing battery, please follow the laws and regulations for proper disposal.
Was du brauchst
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
Carefully pry open the case from several points.
Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
Follow the guide in reverse order to reassemble the device.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
11 Kommentare
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
No, you must have the battery on.
If you have one….
My battery is stuck on orange led mode. My laptop cannot identify the battery….
