Zum Hauptinhalt wechseln
Asus EeeBook X205TA Screen Assembly Replacement
Was du brauchst
  1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: Schritt 1, Bild 1 von 2 Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: Schritt 1, Bild 2 von 2
    • Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA Screen Assembly Replacement: Schritt 2, Bild 1 von 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Screen Assembly Replacement: Schritt 3, Bild 1 von 3 Asus EeeBook X205TA Screen Assembly Replacement: Schritt 3, Bild 2 von 3 Asus EeeBook X205TA Screen Assembly Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the four screws using Philips #2 screwdriver that connect the screen to the inside of the case for the laptop.
  4. Asus EeeBook X205TA Screen Assembly Replacement: Schritt 4, Bild 1 von 1
    • Unplug the No-Fuss Ribbon connector of the screen from the motherboard.
    • Carefully lift the screen away from the case.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 2-2, Sullivan Fall 2016 Mitglied von USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Mitglieder
10 Anleitungen geschrieben
1 Kommentar zur Anleitung
What's that small black screen hanging out from the laptop
Tayler Grant - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 2,644
