Zum Hauptinhalt wechseln
Asus EeeBook X205TA Speakers Replacement
Was du brauchst
  1. Asus EeeBook X205TA Speakers Replacement, Battery: Schritt 1, Bild 1 von 2 Asus EeeBook X205TA Speakers Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Speakers Replacement: Schritt 2, Bild 1 von 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Speakers Replacement: Schritt 3, Bild 1 von 2 Asus EeeBook X205TA Speakers Replacement: Schritt 3, Bild 2 von 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Speakers Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Speakers Replacement: Schritt 5, Bild 1 von 1
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA Speakers Replacement, Speakers: Schritt 6, Bild 1 von 1
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA Speakers Replacement: Schritt 7, Bild 1 von 1
    • Unplug the speaker cable from the motherboard.
  8. Asus EeeBook X205TA Speakers Replacement: Schritt 8, Bild 1 von 1
    • Pry the right speaker gently with the plastic opening tool.
  9. Asus EeeBook X205TA Speakers Replacement: Schritt 9, Bild 1 von 1
    • Pry the left speaker gently with the plastic opening tool.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team S3-G4, Baechle Spring 2017 Mitglied von IUPUI, Team S3-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G4
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Thank you very much for this detailed and helpful tutorial.
andrew - Antwort
Thanks. You’ve helped make it clearer for me!
geometry dash
Martin Tolley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 902
