Zum Hauptinhalt wechseln
Asus F554LA-WS52 Disc Drive
Was du brauchst
  1. Asus F554LA-WS52 Disc Drive, Disc Drive: Schritt 1, Bild 1 von 2 Asus F554LA-WS52 Disc Drive, Disc Drive: Schritt 1, Bild 2 von 2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Disc Drive: Schritt 2, Bild 1 von 3 Asus F554LA-WS52 Disc Drive: Schritt 2, Bild 2 von 3 Asus F554LA-WS52 Disc Drive: Schritt 2, Bild 3 von 3
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Disc Drive: Schritt 3, Bild 1 von 2 Asus F554LA-WS52 Disc Drive: Schritt 3, Bild 2 von 2
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Disc Drive: Schritt 4, Bild 1 von 2 Asus F554LA-WS52 Disc Drive: Schritt 4, Bild 2 von 2
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Disc Drive: Schritt 5, Bild 1 von 3 Asus F554LA-WS52 Disc Drive: Schritt 5, Bild 2 von 3 Asus F554LA-WS52 Disc Drive: Schritt 5, Bild 3 von 3
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Aaron Ratliff
527 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G2, Leahy Fall 2018 Mitglied von USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 559
