Zum Hauptinhalt wechseln
Asus F554LA-WS52 Keyboard Replacement
Was du brauchst
  1. Asus F554LA-WS52 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus F554LA-WS52 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Keyboard Replacement: Schritt 2, Bild 1 von 3 Asus F554LA-WS52 Keyboard Replacement: Schritt 2, Bild 2 von 3 Asus F554LA-WS52 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Flip the notebook back over.
    • Gently lift and remove the keyboard with a plastic opening tool.
  3. Asus F554LA-WS52 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • (Not pictured) Remove the three cables attached to the keyboard and one from the touch-pad.
    • (Not pictured) With the plastic opening tool, pry off the metal separation plate from the keyboard.
    • (Not pictured) With the plastic opening tool, gently pry the keyboard from its position and replace.
Abschluss
Aaron Ratliff
527 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G2, Leahy Fall 2018 Mitglied von USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 312
