Zum Hauptinhalt wechseln
Asus F554LA-WS52 Touchpad Replacement
Was du brauchst
  1. Asus F554LA-WS52 Touchpad Replacement, Touchpad: Schritt 1, Bild 1 von 3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: Schritt 1, Bild 2 von 3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: Schritt 1, Bild 3 von 3
    • Make sure your notebook device is unplugged and turned off before opening it up.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Touchpad Replacement: Schritt 2, Bild 1 von 3 Asus F554LA-WS52 Touchpad Replacement: Schritt 2, Bild 2 von 3 Asus F554LA-WS52 Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
  3. Asus F554LA-WS52 Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
  4. Asus F554LA-WS52 Touchpad Replacement: Schritt 4, Bild 1 von 3 Asus F554LA-WS52 Touchpad Replacement: Schritt 4, Bild 2 von 3 Asus F554LA-WS52 Touchpad Replacement: Schritt 4, Bild 3 von 3
    • Once you've removed the plastic cover, flip it over.
    • Next, carefully remove the tape from the bottom side of your touch pad.
  5. Asus F554LA-WS52 Touchpad Replacement: Schritt 5, Bild 1 von 1
    • Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
  6. Asus F554LA-WS52 Touchpad Replacement: Schritt 6, Bild 1 von 3 Asus F554LA-WS52 Touchpad Replacement: Schritt 6, Bild 2 von 3 Asus F554LA-WS52 Touchpad Replacement: Schritt 6, Bild 3 von 3
    • Gently push the front of the touch pad with your finger to remove it from its position within the keyboard.
    • Replace touch pad.
Abschluss
USF Tampa, Team S1-G2, Leahy Fall 2018 Mitglied von USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 225
