Zum Hauptinhalt wechseln
Asus F555LA-AB31 Hard Drive Replacement
Was du brauchst
  1. Asus F555LA-AB31 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Asus F555LA-AB31 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Asus F555LA-AB31 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Carefully fold the device open.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Asus F555LA-AB31 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Asus F555LA-AB31 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  4. Asus F555LA-AB31 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the ZIF connector and lift the hard drive out of the space.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Boo, 10 screws in first step are not all the same length, 4 screws in third step are not correctly indicated in the image (nor are they all in view in said image). Finally, there’s a hard drive bracket that is not included in the guide which is important to note how it is positioned to reinstall correctly.
Jeb - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 1,830
