Zum Hauptinhalt wechseln
Asus F6A-X2 Hard Drive Replacement
Was du brauchst
  1. Asus F6A-X2 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
  2. Asus F6A-X2 Hard Drive Replacement, Back Access Panel: Schritt 2, Bild 1 von 2 Asus F6A-X2 Hard Drive Replacement, Back Access Panel: Schritt 2, Bild 2 von 2
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
  3. Asus F6A-X2 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Asus F6A-X2 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Asus F6A-X2 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
  4. Asus F6A-X2 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Asus F6A-X2 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Rotate the laptop 90 degrees towards you so that you are looking at the empty battery compartment.
  5. Asus F6A-X2 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Asus F6A-X2 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Remove the 2.0 mm Phillips #3 screw located beneath the battery compartment.
  6. Asus F6A-X2 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Asus F6A-X2 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Asus F6A-X2 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Lay the laptop flat on its back.
    • Gently pull left on the black tab, located on the left side of the hard drive, until it pops out.
    • Slowly lift the tab up and pull the hard drive out of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jonathan
1.174 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 10-56, Amido Spring 2014 Mitglied von Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 833
