Zum Hauptinhalt wechseln
Asus F6A-X2 Hard Drive Replacement
Was du brauchst
  1. Asus F6A-X2 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
  2. Asus F6A-X2 Hard Drive Replacement, Back Access Panel: Schritt 2, Bild 1 von 2 Asus F6A-X2 Hard Drive Replacement, Back Access Panel: Schritt 2, Bild 2 von 2
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
  3. Asus F6A-X2 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Asus F6A-X2 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Asus F6A-X2 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
  4. Asus F6A-X2 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Asus F6A-X2 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Rotate the laptop 90 degrees towards you so that you are looking at the empty battery compartment.
  5. Asus F6A-X2 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Asus F6A-X2 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Remove the 2.0 mm Phillips #3 screw located beneath the battery compartment.
  6. Asus F6A-X2 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Asus F6A-X2 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Asus F6A-X2 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Lay the laptop flat on its back.
    • Gently pull left on the black tab, located on the left side of the hard drive, until it pops out.
    • Slowly lift the tab up and pull the hard drive out of the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jonathan
1.174 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 10-56, Amido Spring 2014 Mitglied von Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 1,050
