Zum Hauptinhalt wechseln
Asus F6A-X2 RAM Replacement
Was du brauchst
  1. Asus F6A-X2 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
  2. Asus F6A-X2 RAM Replacement, Back Access Panel: Schritt 2, Bild 1 von 2 Asus F6A-X2 RAM Replacement, Back Access Panel: Schritt 2, Bild 2 von 2
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
  3. Asus F6A-X2 RAM Replacement: Schritt 3, Bild 1 von 3 Asus F6A-X2 RAM Replacement: Schritt 3, Bild 2 von 3 Asus F6A-X2 RAM Replacement: Schritt 3, Bild 3 von 3
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
  4. Asus F6A-X2 RAM Replacement, RAM: Schritt 4, Bild 1 von 2 Asus F6A-X2 RAM Replacement, RAM: Schritt 4, Bild 2 von 2
    • Make sure to check the RAM specifications on the device page.
    • There are two white plastic tabs holding the RAM in place. Place two fingers on each of these tabs, and pull outward.
    • You will hear a pop and visibly see the RAM move upwards.
    • Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
  5. Asus F6A-X2 RAM Replacement: Schritt 5, Bild 1 von 2 Asus F6A-X2 RAM Replacement: Schritt 5, Bild 2 von 2
    • Repeat the process from the previous step to remove the bottom RAM.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jonathan
1.174 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 10-56, Amido Spring 2014 Mitglied von Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Tutorel simple et très clair.
Merci
alainbadinier - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 574
