Einleitung
Replacing the trackpad on the Asus G501JW-BHI7N12 is a repair that can be done even by new/ low experienced fixers. Should a trackpad become unable, it can make simple task very difficult. Removing the trackpad for a replacement saves you a lot of time, that is normally lost when you sent the laptop out to a repair shop.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Remove the four 7.0mm Philips #0 screws around the battery.
Unplug the connector highlighted in this picture by pulling it up and out of it's seating, then pull the battery away from the motherboard and remove the battery.
Attach an anti static wrist strap to your hand and clip to the laptop case.
Slide cooling fan out from underneath the copper heat sink.
The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
Using the Phillips #0 screwdriver, remove the six 5 mm screws located along the copper heat sink.
Using the same Phillips #0 screwdriver, remove the nine 4 mm screws located around the motherboard.
Using the Phillips #0 screwdriver, remove the three 4 mm screws attached to the trackpad.
