Zum Hauptinhalt wechseln
Asus G73JW-XT1 Optical Drive Replacement
Was du brauchst
  1. Asus G73JW-XT1  Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the device over so the battery port is easy to access.
  2. Asus G73JW-XT1  Optical Drive Replacement: Schritt 2, Bild 1 von 2 Asus G73JW-XT1  Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the left slider to the left so that it locks in place.
    • Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
  3. Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 2 Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: Schritt 3, Bild 2 von 2
    • Turn the device off and remove any power cords. Dissassembling the device while it is under power may result in electric shock and potential damage to the device.
    • Rotate the device so the battery port is facing away.
    • Remove two 5.5 mm Phillips #0 screws on the back panel.
  4. Asus G73JW-XT1  Optical Drive Replacement: Schritt 4, Bild 1 von 3 Asus G73JW-XT1  Optical Drive Replacement: Schritt 4, Bild 2 von 3 Asus G73JW-XT1  Optical Drive Replacement: Schritt 4, Bild 3 von 3
    • Insert the opener tool into the small groove at the edge of the panel.
    • Using opener tool, gently pry the back panel upward until it lifts free from the device.
    • Gently lift the panel off with your fingers.
  5. Asus G73JW-XT1  Optical Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove one 5.5 mm Phillips #0 screw directly to the right of the RAM cards.
  6. Asus G73JW-XT1  Optical Drive Replacement: Schritt 6, Bild 1 von 2 Asus G73JW-XT1  Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Insert the plastic opening tool in the gap between the motherboard and the back panel, directly to the right of the RAM cards.
    • Gently push the optical drive outwards. This should require very little pressure.
    • Grab the loose optical drive with your fingers and pull it free.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 308
