Zum Hauptinhalt wechseln
Asus G750JW-BBI7N05 Display Replacement
Was du brauchst
  1. Asus G750JW-BBI7N05 Display Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Display Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Display Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Display Replacement, Display: Schritt 4, Bild 1 von 1
    • Place your laptop in the upright and open position.
  5. Asus G750JW-BBI7N05 Display Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 4mm Phillips #00 screws from the four corners of the display.
  6. Asus G750JW-BBI7N05 Display Replacement: Schritt 6, Bild 1 von 1
    • Gently pry the front bezel away from the screen and back bezel with an opening tool.
    • The bezel is the outside plastic frame surrounding the screen.
    • You will feel and hear the bezel "unsnap" as you move the pry tool around the entire display.
  7. Asus G750JW-BBI7N05 Display Replacement: Schritt 7, Bild 1 von 1
    • As you work, be mindful of other components that surround the screen, like the WiFi antenna, Bluetooth, webcam, and microphone.
    • Remove the six 6mm Phillips #00 screws across the top of the screen and the four 6mm Phillips #00 screws at the bottom of the screen.
  8. Asus G750JW-BBI7N05 Display Replacement: Schritt 8, Bild 1 von 1
    • With the screws removed, the metal bracket surrounding the screen will feel loose.
    • Remove the top bracket by pulling upwards on the tabs.
  9. Asus G750JW-BBI7N05 Display Replacement: Schritt 9, Bild 1 von 1
    • Remove the four 3mm Phillips #00 screws from the sides of the screen.
  10. Asus G750JW-BBI7N05 Display Replacement: Schritt 10, Bild 1 von 1
    • With the screen free, tilt it gently forward to reveal the display data cable.
    • Unplug the display data cable by peeling off the clear sticker covering its connector, then pulling this connector out of its socket.
    • Make sure to only peel off the sticker that covers the display data cable connector.
  11. Asus G750JW-BBI7N05 Display Replacement: Schritt 11, Bild 1 von 2 Asus G750JW-BBI7N05 Display Replacement: Schritt 11, Bild 2 von 2
    • Remove the two side brackets from the sides of the screen by removing the six 3mm Phillips #00 screws attaching it. There are three screws on either side of the screen.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 2,258
