Zum Hauptinhalt wechseln
Asus G75VW-BHI7N07 Optical Drive Assembly Replacement
Was du brauchst
  1. Asus G75VW-BHI7N07 Optical Drive Assembly Replacement, Optical Drive: Schritt 1, Bild 1 von 3 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement, Optical Drive: Schritt 1, Bild 2 von 3 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement, Optical Drive: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • If you have power, press the eject button.
    • If you don't have power, use the opening tool to pry off the disk drive cover.
    • Press the Manual Eject button with the spudger and the disk drive should slide out. (Might need tweezers if it doesn't pop out immediately)
    • Once the disc drive pops out, flip the laptop over.
  2. Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: Schritt 2, Bild 1 von 2 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: Schritt 2, Bild 2 von 2
    • Remove the 4 screws that hold down the metal plate with the J0 Phillips-head screwdriver.
    • Put the screws onto the magnetic pad, to avoid losing any.
    • Lift the metal plate off the optical drive with your fingers.
  3. Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: Schritt 3, Bild 1 von 2 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: Schritt 3, Bild 2 von 2
    • Remove 3 screws of disc drive with the J0 Phillips-head screwdriver.
    • Pick up the disc drive assembly and pull it out.
  4. Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: Schritt 4, Bild 1 von 3 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: Schritt 4, Bild 2 von 3 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: Schritt 4, Bild 3 von 3
    • Remove optical assembly by hand.
    • Remove disc reader by removing 2 bolts from the top using the J0 Phillips-head screwdriver.
    • Lift the metal piece out.
    • Make sure no edges are sticking out when putting the metal plate back in place.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Joy
437 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 869
