Zum Hauptinhalt wechseln
Asus GL551JW-AH71 Wi-Fi Card Replacement
Was du brauchst
  1. Asus GL551JW-AH71 Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Asus GL551JW-AH71 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 Asus GL551JW-AH71 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 2 Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 2 von 2
    • Using a Phillips #000 screwdriver, remove the two 16mm screws securing the access panel to the laptop.
  5. Asus GL551JW-AH71 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the cover once the screws are removed.
  6. Asus GL551JW-AH71 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Locate the Wi-Fi card and detach both coaxial cables that are connected to the card.
    • The pictures in this step do not show a Wi-Fi card. The location where the Wi-Fi card would be located is indicated by the red rectangle.
  7. Asus GL551JW-AH71 Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Grasp the Wi-Fi card gently and remove it carefully.
    • The pictures in this step do not show a Wi-Fi card, since it is missing from this particular device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
William Kelley
1.035 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S8G3
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 1,105
