Einleitung
This guide will provide a quick and easy procedure for replacing your Wi-Fi card. This particular guide could also be referred as a prerequisite for other guides on RAM, motherboard and fan.
Was du brauchst
Using a Phillips #000 screwdriver, remove the two 16mm screws securing the access panel to the laptop.
Locate the Wi-Fi card and detach both coaxial cables that are connected to the card.
2 weitere Personen haben diese Anleitung absolviert.
