Zum Hauptinhalt wechseln
Asus K53E-BBR3 Hard Drive Replacement
Was du brauchst
  1. Asus K53E-BBR3 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Asus K53E-BBR3 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Asus K53E-BBR3 Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Hard Drive Replacement, Back Panel: Schritt 2, Bild 1 von 1
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Unscrew the four 5mm Phillips #1 screws.
    • Lift the hard drive out of the computer.
  5. Asus K53E-BBR3 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Asus K53E-BBR3 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the screws on the hard drive case.
    • Two 3mm Phillips #1 screws are located on one edge of the case.
    • The last two 3mm #1 Phillips screws are located on the opposite side of the case.
    • After you unscrew all four screws, the metal cage will fall off, leaving you with the hard drive.
Abschluss
UMass Dartmouth, Team 1-1, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 1,754
