Einleitung
Hard drive space is constantly filled up with today's large file sizes. So adding a bigger and better hard drive is a common practice. This guide will demonstrate how to unscrew the back panel from the laptop and then to replace the hard drive.
Was du brauchst
Place your laptop face down in front of you.
Slide the button in the top right corner to the right so that the orange marker is showing.
Press the spring loaded latch to release the battery from the computer.
Unscrew the four 5mm Phillips #1 screws.
Lift the hard drive out of the computer.
Unscrew the screws on the hard drive case.
Two 3mm Phillips #1 screws are located on one edge of the case.
The last two 3mm #1 Phillips screws are located on the opposite side of the case.
After you unscrew all four screws, the metal cage will fall off, leaving you with the hard drive.
