Zum Hauptinhalt wechseln
Asus K53E-BBR3 Keyboard Replacement
Was du brauchst
  1. Asus K53E-BBR3 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Asus K53E-BBR3 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Asus K53E-BBR3 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: Schritt 2, Bild 2 von 3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: Schritt 2, Bild 3 von 3
    • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
    • Insert the spudger into the indent near the "ESC" key.
    • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
  3. Asus K53E-BBR3 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Gently pull the ribbon cable to the right and out of its port.
Abschluss
Liza Sousa
355 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-1, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 774
