Zum Hauptinhalt wechseln
Asus K550VX Thermal Paste Replacement
Was du brauchst
  1. Asus K550VX Thermal Paste Replacement, Disassembly 1.: Schritt 1, Bild 1 von 2 Asus K550VX Thermal Paste Replacement, Disassembly 1.: Schritt 1, Bild 2 von 2
    • Remove the battery and unscrew the 2 screws that hold the back panel in place.
    • Remove the SSD and the rest of the screws that hold the palmrest.
    • Here you can upgrade the SSD and RAM before finishing the reassembly.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus K550VX Thermal Paste Replacement, Disassembly 2.: Schritt 2, Bild 1 von 2 Asus K550VX Thermal Paste Replacement, Disassembly 2.: Schritt 2, Bild 2 von 2
    • Use a prying tool to release all the clips of the palmrest.
    • Carefully disconnect the keyboard, touchpad and power button connectors.
    • Remove the palmrest to reveal the motherboard.
    Frag FixBot
  3. Asus K550VX Thermal Paste Replacement, Disassembly 3.: Schritt 3, Bild 1 von 3 Asus K550VX Thermal Paste Replacement, Disassembly 3.: Schritt 3, Bild 2 von 3 Asus K550VX Thermal Paste Replacement, Disassembly 3.: Schritt 3, Bild 3 von 3
    • Unscrew and remove the Wi-Fi module (BLUE). The anthennas do not need to be disconnected as it can be tucked away, but if you feel more comfortable, disconnect them.
    • Unscrew and remove the DVD drive (YELLOW).
    • Disconnect all the connectors (GREEN).
    • Unscrew all the other screws and carefully lift the motherboard from the DVD connector, flip it, disconnect the power connector (ORANGE) and slide the motherboard out.
    • Unscrew the heatsink (RED) and disconnect the fan connector (PINK).
    • To clean the fan, the black tape (BLACK) has to be removed so it can be separated from the heatsink. You can use electrical tape to replace it after that. I highly recommend doing this, because there can be a lot of dust and dirt hiding between the two.
    • It is also recommended to use compressed air to remove any dust in the laptop case itself.
    Frag FixBot
  4. Asus K550VX Thermal Paste Replacement, Replacing the thermal paste.: Schritt 4, Bild 1 von 1
    • Clean the old thermal paste both from the cooler and the CPU+GPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU+GPU.
    • Don`t use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order to ensure even pressure.
    • Don`t forget to plug in the fan connector!
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 42
Insgesamt: 496
