Einleitung
If your Asus K55VD is having problems reading DVDs, not playing audio or videos properly, or DVD programs won't install properly then it may be experiencing a faulty optical disk drive which needs to be replaced.
Was du brauchst
Schritt 1 Battery
Achtung: Schritt 1 stammt von einer Anleitung, die derzeit bearbeitet wird.
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
After removing the screws, remove the smaller cover.
Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
Using the the Philips #0 Screwdriver remove highlighted screws.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
