Einleitung
The Asus K55A-Si50301P Hard Drive Replacement Guide explains the tools and process used to replace/remove the Hard Drive as needed. The hard drive may occur to be damaged/faulty when general hardware such as screws become loose and release the drive from its connection. The Asus K55A-Si50301P Troubleshooting page may be referred to hereas needed.
Was du brauchst
Press and slide the two battery retention clips on either side of the battery towards the unlock position.
Pull the retention clip on the left hand side of the laptop away from the battery.
Gently pull the battery out with your free hand.
Using the iFixit opening tool, gently pry the plastic cover away from its original position.
Disconnect the SATA link from the hard drive by pulling back on the grey connector.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
