Zum Hauptinhalt wechseln
Asus M51E-B2 Swivel Camera Replacement
Was du brauchst
  1. Asus M51E-B2  Swivel Camera Replacement, Swivel Camera: Schritt 1, Bild 1 von 1
    • Open the laptop.
    • Press and hold the power button until the laptop powers off.
  2. Asus M51E-B2  Swivel Camera Replacement: Schritt 2, Bild 1 von 2 Asus M51E-B2  Swivel Camera Replacement: Schritt 2, Bild 2 von 2
    • Use a metal spudger prying tool to remove the outer screen cover of the laptop.
    • Gently work your way clockwise around the outer part of the screen.
  3. Asus M51E-B2  Swivel Camera Replacement: Schritt 3, Bild 1 von 2 Asus M51E-B2  Swivel Camera Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips PH0 head screwdriver to remove the two 2.5 mm screws located on the left side of the camera.
    • Use the Phillips PH0 head screwdriver to remove the one 2.5 millimeter screw that goes through the left side of the camera.
  4. Asus M51E-B2  Swivel Camera Replacement: Schritt 4, Bild 1 von 1
    • Find the wiring harness on the right side of the camera.
    • Using your fingers, gently remove the wiring harness connected to the right side of the camera.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 285
