Einleitung
This guide will show you how to replace a battery for a Asus MeMO Pad 7. The battery replacement is a simple procedure. If the battery is dead, the replacement could help your tablet to turn on.
Was du brauchst
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
Carefully run the plastic opening tool along all the edges of the tablet.
When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
