Zum Hauptinhalt wechseln
Asus MeMO Pad 7 ME170C Battery Replacement
Was du brauchst
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: Schritt 2, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Battery Replacement: Schritt 2, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Battery Replacement: Schritt 2, Bild 3 von 3
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: Schritt 3, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Battery Replacement: Schritt 3, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Battery Replacement: Schritt 3, Bild 3 von 3
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 3,200
