Einleitung
The microphone is where you input sound, as opposed to the speaker which is what outputs sound. This is where you record voice memos, give commands to a built in operating system, or voice to text functions.
Was du brauchst
Using the Jimmy tool, gently wedge it into the seam of the device.
Gently pry the Jimmy tool all around the seam until the back panel is detached.
Inserted in a black port on the motherboard, locate the white cable connector on the left side of the tablet.
In a side to side motion, using the smallest opening tool, slide the white cable box completely out of the port towards the bottom of the device.
Using wide nosed tweezers, lift up the tape and remove from black box.
Remove the component completely from the device.
