Zum Hauptinhalt wechseln
Asus MeMO Pad 7 ME170C Power and Volume Button Replacement
Was du brauchst
  1. Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Battery: Schritt 1, Bild 1 von 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Battery: Schritt 1, Bild 2 von 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: Schritt 2, Bild 1 von 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: Schritt 2, Bild 2 von 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: Schritt 2, Bild 3 von 3
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: Schritt 3, Bild 1 von 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: Schritt 3, Bild 2 von 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement: Schritt 3, Bild 3 von 3
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
  4. Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Power and Volume Button: Schritt 4, Bild 1 von 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Power and Volume Button: Schritt 4, Bild 2 von 3 Asus MeMO Pad 7 ME170C Power and Volume Button Replacement, Power and Volume Button: Schritt 4, Bild 3 von 3
    • Locate the cable that connects the power button to the motherboard.
    • Carefully lift and release the connector lock that keeps it attached the motherboard. The connector lock rotates up away from the connection to release.
    • Carefully release the connection from the motherboard.
    • Gently pry the power and volume button away from the case. There should not be much resistance when prying the button off.
Abschluss
Thomas Brooks
301 Reputation
3 Anleitungen geschrieben
IUPUI, Team S3-G3, Wilson Spring 2017 Mitglied von IUPUI, Team S3-G3, Wilson Spring 2017
IUPUI-WILSON-S17S3G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 569
