Einleitung
The speaker is where sound comes out. When videos or music are played too loudly, it can cause the speaker to blow. This is a component of the Memo Pad that needs to be replaced when this problem occurs.
Was du brauchst
Using the Jimmy tool, gently wedge it into the seam of the device at the side.
Pry the Jimmy tool gently all around the seam. Use up and down motions until the back panel is detached.
From the top of the tablet, locate the white cable connector.
Use the blue plastic opening tool to push the white cable connector out of the port.
Use the Phillips #000 screwdriver to remove the seven screws.
There should be two silver and five black screws for a total of seven screws.
Use the slender, metal spudger tool to gently lift up the edge of the speaker to remove the device.
Eine weitere Person hat diese Anleitung absolviert.
