Zum Hauptinhalt wechseln
Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
Was du brauchst
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: Schritt 1, Bild 1 von 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: Schritt 1, Bild 2 von 2
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 2, Bild 1 von 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 2, Bild 2 von 2
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 3, Bild 1 von 1
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 4, Bild 1 von 1
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 5, Bild 1 von 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 5, Bild 2 von 2
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 6, Bild 1 von 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 6, Bild 2 von 2
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 7, Bild 1 von 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 7, Bild 2 von 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 7, Bild 3 von 3
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 8, Bild 1 von 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 8, Bild 2 von 2
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 9, Bild 1 von 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 9, Bild 2 von 2
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 10, Bild 1 von 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 10, Bild 2 von 2
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 11, Bild 1 von 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 11, Bild 2 von 2
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 12, Bild 1 von 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 12, Bild 2 von 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: Schritt 12, Bild 3 von 3
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
Abschluss
Nejad Harara
110 Reputation
1 Anleitung geschrieben
Cal Poly, Team S6-G3, Banghart Fall 2017 Mitglied von Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,676
