Einleitung
This guide will take you through the necessary steps to disassemble your Asus MeMO Pad 7 ME176C to replace the screen.
Was du brauchst
Insert plastic opening tool in between screen and back cover to create initial separation between the two.
Then run plastic opening tool along end of screen to fully separate back cover from screen.
Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
Disconnect speaker wire from motherboard using metal pronged tweezers.
Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
Remove the black bundle battery connector from the motherboard using plastic opening tools.
Remove speaker housing to expose ZIF connection underneath.
Then using metal tweezers disconnect the ZIF connector.
Remove motherboard from hard frame.
When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
