Einleitung
Read through this guide if you are experiencing problems regarding your Asus MeMO Pad HD 8 ME180A's battery.
Was du brauchst
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
Ensure that you are wearing your Anti-Static Wrist Strap.
Using your spudger, press down on the two spots shown in order to release the cables.
Ensure that the touchscreen cables are fully disconnected.
Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
Pull the battery out.
