Einleitung
You will learn how to replace the camera. Review this guide if you are having difficulties with the camera. In order to replace the camera, you have to remove the battery and motherboard. Please use our Asus MeMO Pad HD 8 ME180A Battery Replacement Guide and Asus MeMO Pad HD 8 ME180A Motherboard Replacement Guide to do so prior to starting.
Was du brauchst
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
Ensure that you are wearing your Anti-Static Wrist Strap.
Using your spudger, press down on the two spots shown in order to release the cables.
Ensure that the touchscreen cables are fully disconnected.
Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
Pull the battery out.
Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
Lift the motherboard straight up to remove.
Upon removal of the motherboard, flip the motherboard to the side so the front-face camera faces you.
Remove the front facing camera.
Upon removal of the front-face camera, flip your device to the side so the back-face camera faces you.
Using a pair of tweezers, grab the back-face camera and pull it straight out.
