Einleitung
You will learn how to replace the motherboard. Review this guide if you are having difficulties with the motherboard. In order to replace the motherboard, you have to remove the battery. Please use our Asus MeMO Pad HD 8 ME180A Battery Replacement Guide to do so prior to starting.
Was du brauchst
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
Ensure that you are wearing your Anti-Static Wrist Strap.
Using your spudger, press down on the two spots shown in order to release the cables.
Ensure that the touchscreen cables are fully disconnected.
Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
Pull the battery out.
Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
Lift the motherboard straight up to remove.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Où je peux avoir une carte mère pour asus memo pad8 me 180
Shouldn’t there be a step to handle the camera?
