Einleitung
How to disassemble the Memo Pad and replace the LCD display.
Was du brauchst
Einführungsvideo
Disconnect the LCD display flex cable.
Disconnect the touch screen flex cable.
Disconnect and remove the loudspeaker.
Unscrew 10x screws and remove the mother board.
The LCD display is held from a metal frame, glued to the touch screen. By using cutter, start carefully open the frame to remove the LCD display.
Did you do it successfully?
5 weitere Nutzer:innen haben diese Anleitung absolviert.
