Einleitung
How to replace broken or not working touchscreen.
WARNING! Work carefully and start only if you are confident you can do it!
Was du brauchst
Einführungsvideo
Switch-off the tablet.
By using a plastic tool open the back / battery cover.
Disconnect the LCD display flex cable.
Disconnect the touchscreen flex cable.
Disconnect and remove the loudspeaker.
Unscrew 10x screws.
Now you can remove the mother board
There are many clips holding the LCD panel to the metal frame.
Use a spudger to loosen the clips holding the LCD display.
Heat the touch screen.
Use a cutter only to start detachment the touchscreen. Then continue with a plastic tool.
After separation the touchscreen from the front bezel, remove the LCD display frame.
This spare part have a double sided adhesive tape. Otherwise you should place.
Did you do it successfully?
8 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Is it possible to replace the bezel the way you would an iPad screen instead of going from the back? I feel like a head gun to the front would save you a lot of hassle? Please correct me if I'm wrong
