Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
How to replace broken or not working touchscreen.
WARNING! Work carefully and start only if you are confident you can do it!
Please SUBSCRIBE to my channel ツ
Ersatzteile
Einführungsvideo
  1. Switch-off the tablet. By using a plastic tool open the back / battery cover. By using a plastic tool open the back / battery cover.
    • Switch-off the tablet.
    • By using a plastic tool open the back / battery cover.
  2. Disconnect and remove the battery. Disconnect and remove the battery. Disconnect and remove the battery.
    • Disconnect and remove the battery.
  3. Disconnect the LCD display flex cable. Disconnect the touchscreen flex cable. Disconnect and remove the loudspeaker.
    • Disconnect the LCD display flex cable.
    • Disconnect the touchscreen flex cable.
    • Disconnect and remove the loudspeaker.
    • Unscrew 10x screws.
    • Now you can remove the mother board
  4. Remove the metal LCD display shield. Remove the metal LCD display shield. Remove the metal LCD display shield.
    • Remove the metal LCD display shield.
  5. There are many clips holding the LCD panel to the metal frame. Use a spudger to loosen the clips holding the LCD display. Use a spudger to loosen the clips holding the LCD display.
    • There are many clips holding the LCD panel to the metal frame.
    • Use a spudger to loosen the clips holding the LCD display.
  6. Heat the touch screen. Use a cutter only to start detachment the touchscreen. Then continue with a plastic tool. Use a cutter only to start detachment the touchscreen. Then continue with a plastic tool.
    • Heat the touch screen.
    • Use a cutter only to start detachment the touchscreen. Then continue with a plastic tool.
  7. After separation the touchscreen from the front bezel, remove the LCD display frame. This spare part have a double sided adhesive tape. Otherwise you should place. .
    • After separation the touchscreen from the front bezel, remove the LCD display frame.
    • This spare part have a double sided adhesive tape. Otherwise you should place.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
ZFix
177.254 Reputation
317 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
295 Mitglieder
974 Anleitungen geschrieben
Is it possible to replace the bezel the way you would an iPad screen instead of going from the back? I feel like a head gun to the front would save you a lot of hassle? Please correct me if I'm wrong
Alex Tucker - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 9
Insgesamt: 23,260
