Zum Hauptinhalt wechseln
Asus P53E replacement of hard drive or replacement by a SSD Replacement
Was du brauchst
  1. Asus P53E replacement of hard drive or replacement by a SSD Replacement, replacement of hard drive or replacement by a SSD: Schritt 1, Bild 1 von 1
    • unscrew these two screws to remove the coverage
  2. Asus P53E replacement of hard drive or replacement by a SSD Replacement: Schritt 2, Bild 1 von 1
    • unscrew these four screws to take out the case with the hard drive disk
  3. Asus P53E replacement of hard drive or replacement by a SSD Replacement: Schritt 3, Bild 1 von 1
    • slip the hard drive to the left
  4. Asus P53E replacement of hard drive or replacement by a SSD Replacement: Schritt 4, Bild 1 von 1
    • pull the strap to remove the hard drive's case
  5. Asus P53E replacement of hard drive or replacement by a SSD Replacement: Schritt 5, Bild 1 von 1
    • unscrew the four screws of the case to remove the hard drive out of that case
  6. Asus P53E replacement of hard drive or replacement by a SSD Replacement: Schritt 6, Bild 1 von 1
    • remove the hard drice from its case
  7. Asus P53E replacement of hard drive or replacement by a SSD Replacement: Schritt 7, Bild 1 von 1
    • put the new hard drive or SSD, respectively in the case and fix the screws again (the HDD/SDD will only fit in the case in one way)
  8. Asus P53E replacement of hard drive or replacement by a SSD Replacement: Schritt 8, Bild 1 von 1
    • slip the case to the right to plug in the HDD/SDD again
  9. Asus P53E replacement of hard drive or replacement by a SSD Replacement: Schritt 9, Bild 1 von 1
    • close the case again
Abschluss
Mojo
113 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 2,093
