Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to replace the logic board of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. This guide requires some skill and you must be careful when following directions. This guide will help you with other replacement guides for the Asus PadFone S.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place your thumb in the charging port and pry the back cover off of the phone.
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Remove all screws using the T5 Torx screwdriver Lift the back panel off the phone.
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Disconnect the battery from the logic board using tweezers Using the plastic opening tools, lift the battery up from its slot
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Disconnect all wires and bands from microphone, SIM card port and side bottons Disconnect all wires and bands from microphone, SIM card port and side bottons Disconnect all wires and bands from microphone, SIM card port and side bottons
    • Disconnect all wires and bands from microphone, SIM card port and side bottons
  5. Disconnect remaining band from the logic board Lift the logic board out of the phone Lift the logic board out of the phone
    • Disconnect remaining band from the logic board
    • Lift the logic board out of the phone
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Greg Betsold
96 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 Mitglieder
5 Anleitungen geschrieben
need schematic side button asus padfone s..please send via email kepkep.erwin@gmail.com.
thanks..
kepkep - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 3,432
