Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to remove the side buttons of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. This guide will make it easy to replace a broken side buttons to get your phone working again.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place your thumb in the charging port and pry off the back cover.
    • Place your thumb in the charging port and pry off the back cover.
  2. Remove all screws using a T5 Torx screwdriver. After removing screws, lift the back panel off of the phone.
    • Remove all screws using a T5 Torx screwdriver.
    • After removing screws, lift the back panel off of the phone.
  3. Turn the phone so the left edge is facing you.
    • Turn the phone so the left edge is facing you.
    • Using your fingers, gently pull up on the buttons to remove them from the phone.
Abschluss
Greg Betsold
96 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 Mitglieder
10 Anleitungen geschrieben
My Asus Padfone S Side
Buttons Got Error ..
Its Press It But No Peanuts ( Klik Sound ) Inside :(
How To Fix It ??
By Ndra - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 950
