Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Hold down power button to shut off phone.
    • Hold down power button to shut off phone.
  2. Use plastic opening tool to pry off the back cover of the phone. Use plastic opening tool to pry off the back cover of the phone.
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Remove the warning sticker that covers the battery plug and connecting cord. Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out. The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Disconnect battery connecting cord using tweezers.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Zach Standridge
350 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-4, Mcgee Fall 2014 Mitglied von USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Mitglieder
7 Anleitungen geschrieben
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 5,509
