Zum Hauptinhalt wechseln
  1. Asus Padfone 2 Vibrator Replacement, Power Down Device: Schritt 1, Bild 1 von 1
    • Hold down the power button
  2. Asus Padfone 2 Vibrator Replacement, Remove Back Plate: Schritt 2, Bild 1 von 3 Asus Padfone 2 Vibrator Replacement, Remove Back Plate: Schritt 2, Bild 2 von 3 Asus Padfone 2 Vibrator Replacement, Remove Back Plate: Schritt 2, Bild 3 von 3
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Vibrator Replacement, Battery Removal: Schritt 3, Bild 1 von 3 Asus Padfone 2 Vibrator Replacement, Battery Removal: Schritt 3, Bild 2 von 3 Asus Padfone 2 Vibrator Replacement, Battery Removal: Schritt 3, Bild 3 von 3
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: Schritt 4, Bild 1 von 2 Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: Schritt 4, Bild 2 von 2
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: Schritt 5, Bild 1 von 2 Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: Schritt 5, Bild 2 von 2
    • Use tweezers to remove motor from housing, pulling the plug downward away from the phone.
    • Use tweezers to unplug the device from the circuit board.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Zach Standridge
350 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-4, Mcgee Fall 2014 Mitglied von USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 1,284
